Horizontal lines on 2/3 of my screen
Hello everybody, from this morning i've a problem with my screen. It has grey horizontal lines on the 2/3 of it. image
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hook it up to an external monitor. If you get a bad picture then Brain is probably correct. To be sure you have the Nvidia processor please give us the last three figures of your serial number. If you are not close to an Apple store, the Nvidia issue can be handled in four days (start to finish) over the phone.
このアンサーは役に立ちましたか?
The last three figures of my S/N are X92.
you have nvidia Video Card: GeForce 8600M GT VRAM Type: GDDR3 SDRAM
Details: The NVIDIA GeForce 8600M GT with 256 MB of GDDR3 SDRAM uses a 16 lane PCI Express bus.
I would check with your local apple store, there is a recall for the nvidia graphics chipset for this model MBP...... they run a simple test and if applicable your logicboard would be replaced under recall...... i would recommmed an apple store as i have had the best results in correctly diagnosing this problem and having it fixed under the recall quickly.
If it is not a graphics chip issue can trouble shoot from there if the apple store tech don't just go ahead and tell you what the problem is.
このアンサーは役に立ちましたか?
It is hardware problem contact to a repairer. All this is because of stress please be careful about your system. Children must not to touch it without you.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,112
1件のコメント
End of the history. Screen is broken. 436€ to change it (taxes inluded). !#^*
gianlucapat さんによる
