メインコンテンツにスキップ
Samsung Galaxy Note10はSamsungより2019年8月に発売されました。
23回答 すべてを表示
How can I remove a S-Pen that has been stuck in the device?
I dropped my phone the day my protective case came in the mail, as I was on my way to get the mail (a couple days after receiving my Note 10+ as a long-awaited replacement for another broken phone.)
Since then, my S-Pen has been stuck in the S-Pen slot, and does not “click” and pop out. There is a slight dent in the S-Pen Slot, but after a little bit of light force to bend it back in place to the point that using my 60x lighted handheld loupe I strongly believe the S-Pen should probably be able to escape and that the blockage is coming from further within the S-Pen compartment.
My concern is that the battery in the S-Pen itself, or some aspect of the phone underneath the wireless charger is out of whack. After reviewing your Note 10+ information, and anything I could find on youtube, I did not see anything about how to safely remove the S-Pen’s wireless charger, so that you could then dislodge the S-Pen itself.
With back glass and adhesive being fairly inexpensive I don’t mind popping off the glass at the risk of damaging that to try to get it out, but I don’t want to start digging around without a better idea of how to do it properly.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
If as you say the passageway for the S-Pen is clear, then it more than likely will come out with just a bit of force. Lightly bump the phone against your hand or a table and hopefully the device will come free.
If that doesn’t work, you may be able to try taking the back and screen off the device and seeing if there is any debris or damage to the compartment for the S-Pen, and hopefully be able to revert it.
If all else fails, you can resort to drilling into the pen, sacrificing it’s life, so you can then remove the corpse from the device and replace it.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
This was helpful thank you so much
さんによる
コメントを追加
I recently got my s pen stuck and I freaked out and tried everything and then a got an idea. I grabbed some tape, doesn't really matter it just has to be new or slightly used. From there you have to put some tape on the stuck pen and gently pull it so the inside dosen't get damaged and it worked.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
My pen broke in half. I tried this and I couldn't get it out. A friend with a "Swiss type" knife used a tip and it took two of us getting it out.
さんによる
コメントを追加
Late to the party but just had this issue.
I've had 2 pens break, leaving 1/2 stuck in the slot. Tweezers got them out.
Last week my brand new, intact pen got stuck. After reading this post, I bumped the bottom of the phone against my palm and the pen popped right out. Quick swipe with a Q-Tip confirmed that there was dust & hair in the slot; very little, actually. Apparently, it doesn't take much to gum up the works. The pen is now snapping in and out smoothly. Plan to swipe again with alcohol to remove oil that may have transferred from the pen to the slot. Might sound like overkill but I depend on the pen. Without it, I fat-finger everything.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
no working for me. i just use pen for one time. then put it back in. but it stuck so much. i think it's because of dust or hair. I feel so !#^&. what should I do. i don't want bring them to repair because it's new phone to me. just wanna use pen so bad, grr
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Teddy Trocki-Ryba さん、ありがとうございました!
統計データ:
過去 24時間: 24
過去 7 日: 179
過去 30 日: 803
今までの合計 15,213
