Will not boot / Pulled top cover and got it to boot
The MacBook would not boot. I could hear the disc drive make noise and the fan come on but no video or booting. I pulled the top case and put it back on and then all the sudden it booted when I push P R option command keys after booting. I had the top case sitting on top and and it booted and was at the desktop in the OS when all the sudden it went black. Seems like a loose cable. Now it is back to where I started and I can't get it to boot again.
Is there a way to boot without the top case? I can't find any jumper on the logic board on this model.
この質問は役に立ちましたか?
2 件のコメント
I found it. Thank you for the picture. It turns on the same (shorting the pins) as with the top cover and power button. The fan starts and the disc drive but nothing else. So that rules out the top cover. Seems like it has to be a loose connection somewhere since it started fine and then stopped again.
What connectors would do this? WHat should I check next?
Chase さんによる
Anyone know what I can check next?
Chase さんによる
