Why after 5 minutes of starting the xbox, it stops by itself?
I changed the thermal paste, cleaned it of dust inside and the Xbox stops after 5 minutes when I turned it on. What can I do?
If your Xbox console is unexpectedly shutting down, it may be because it’s not getting enough ventilation, or there may be a problem with the power supply. Try the following solutions.
Solution 1: Check if the console is too hot;
Solution 2: Troubleshoot your power supply;
Solution 3: Change the consloe settings so it doesn’t turn off automatically;
Solution 4: Perform a system reset to clear any corruption.
If you’ve followed these steps but the console continues to shut down unexpectedly, you can request a repair.
このアンサーは役に立ちましたか?
don't work this
@Dnk 05 Have you ever encountered Xbox overheat issuer before? Also check out another thread of the same issue. New thermal paste and pads - system overheating and shutting down
@v3nuo I also changed the thermal paste and I cleaned it of dust, I also changed the hard disk and the power supply
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 82
If the fans spin like crazy before it shuts off you probably applied too little thermal paste or didn't fasten the heat sink screws enough
Roman Prochazka さんによる
@pomikoli everything is normal with the xbox
Dnk 05 さんによる
