メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
iPhone 8 Won't Turn On, No screen, Very hot
Hello!
My iPhone 8 has stopped working after I charged it, the screen was black and the phone was very hot, I tried ‘hard reset’ and charge it after my battery was drained. However, it didn’t work at all (not getting even warm from charging). I ordered a new battery and a board to charge the battery. The old battery was dead, I couldn’t charge it even with the board. The phone still didn’t boot up with the new battery, the screen was black, the board got hot in the upper part
Here are my phone’s measurements https://ibb.co/0cmjNhf
Actual photos of the board. https://ibb.co/ThBmkdn
https://ibb.co/TkShJ3f
Thanks in advance for any help!
Edit: Found out that u3100 is getting very hot.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
https://youtu.be/U8CG9c7oEEg?t=177
Can anyone tell me what kind of rosin or what is he using to make it, I have been looking for freezing spray but I didn’t find one where I live… if there other methods I would like to hear them too.
thanks
さんによる
コメントを追加
2件の回答
ベストアンサー
The board has developed a short, most likely on the PP_VDD_MAIN line. Test this line first. I have marked a test point for you.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for your fast reply. I'm not sure what 'PP_VDD_MAIN' is as I don't have any schematics of the phone.
The test point you marked shows 408
さんによる
@mrfarnhigh That reading doesn’t sound right but it is not shorted. You need to rule out faulty parts first, after that you will need a set of schematics and Broadview software as well as other testing equipment like a DCPS and some squid connectors to diagnose any further.
さんによる
コメントを追加
This might either be because of the battery or overheating. Try to remove the battery or cool the wole phone for a day, and then turn on.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks, but it is not the case.
さんによる
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 313
