メインコンテンツにスキップ
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
630回答 すべてを表示
Ipad Mini Won't Respond.
The Mini Ipad does not respond at all. It worked perfectly until the home button was unresponsive. Then, the home screen became like a “glitch” when I turned it back on after I turned it off to do work outside. I can’t press the pass code or anything to get in. Every time I turned on the home screen, it then “glitches” and fades to black. Somehow, the home button was working again but only for the power reset. I then hold both the power buttons to reset it but it then made it worse. I turned it back on, the Apple Logo appears, and then it fades away like a “glitch” to a black screen. I even tried doing it with a charger on as well.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
What happens when you do a soft reset (hold home button & power simultaneously)? If that doesn’t reset it, can you connect to a Mac & restore it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Blue Dude [G] さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 17
