メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2020年4月に発表、発売された第二世代iPhone SEの修理と解体情報です。
51回答 すべてを表示
Why is it boot looping
It will boot loop and turn on and let me unlock it sometimes, not sure if this is a battery issue or not, i bought it second hand and has had a screen replacement (not by apple)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Bet this is part of apples anti repair things
さんによる
i have done some troubleshooting and the microphone and camera connection seems to be the problem, when it is not connected it works fine but once it is connected it will boot loop once again.
さんによる
コメントを追加
1 件の回答
What you can do is connect it to a computer running itunes. You will need to turn it off, then turn it on holding both the power button down. Maybe different in this model. Attached an article. You will want to see it enter recovery mode where it asks you to connect to itunes. Sometimes works.
How to Enter Recovery Mode on iPhone SE (2020 Model) (osxdaily.com)
このアンサーは役に立ちましたか?
スコア 0
コメント:
If you get the phone into recovery mode, you'll want to download an appropriate ipsw-file, then in itunes, you click 'restore', but hold down the shift-button, which will let you select the ipsw you've already downloaded to fully restore the phone. If none of this works, you could try DFU-mode..
さんによる
hi, its a hardware issue
i have done some troubleshooting and the microphone and camera connection seems to be the problem, when it is not connected it works fine but once it is connected it will boot loop once again."
さんによる
Ok. Sometimes, you can still get away with a solution like described above. I see your point, but hypothetically possible it could be a hardware/software combo. (ie if for instance software problems loop when loading mic/camera)
さんによる
コメントを追加
回答を追加する
Ethan Lewis さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 31
