Why is my phone not responding?
Dropped my iPhone 6 it turns on but the screen is black and won't respond to any PC when plugged in, tired reconnecting the screen cable but nothing.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Unless the PC was trusted by the phone previously, it won’t detect it. Odds are you damaged the LCD assembly. If you plug it into the charger and give it a few minutes, either try to call it or toggle the mute switch. If it rings or vibrates with no image, then it’s most likely the screen and you would have confirmed the phone is powered on. You can order replacement kits here on iFixit or you could take it to a local independent repair shop.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 16
