メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
Audio stopped working: No output or input devices found
My audio has stopped working. Using the sound preferences window, I am able to see that it say that it says “No output devices found” and “No input devices found”. After doing some reading, it seemed like the most likely cause was the I/O board. So I ordered a replacement from IFIXIT and replaced the board. The replacement worked find, for a single day! The next day it was back to the same old no devices found problem.
My question is did I just get a replacement I/O board (it was used, since that was all they offered) and I should just try replacing it again? (It seems like a waste of time.) Or is this some sort of deeper problem? Is this a common problem on the Macbook Air (Early 2015 edition, model A1466) that has a more root cause and, hopefully, solution?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
You can try the terminal command for stoping and further reseting the USB connections. So plug out all devices run command in the terminal then try and plug them back again. If that doesnt work you can try and reboot your mac. SMC reset can also do some magic and its harmless.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Most likely your I/O board cable just needs to be reseated or replaced. At worse your I/O board has failed. The Cirrus audio DAC chip is located on it.
Here’s the guide MacBook Air 13インチ Early 2015 I/Oボードの交換
Replace an I/O Board Cable compatible with the Mid 2013 to 2017 13" MacBook Air laptop. Fix the connection between the I/O Board and the Logic Board.の画像
製品
MacBook Air 13" (Mid 2013-2017) I/O Board Cable
$14.99
Replace a used I/O board compatible with the Mid 2013 to 2017 MacBook Air 13" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe 2 power, USB, and audio ports.の画像
製品
$52.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Wesley Irish さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 743
