メインコンテンツにスキップ
モデル番号A1288/ 8, 16もしくは32 GB容量
451回答 すべてを表示
Password disabled
I put in a password and i forgot it,so i kept on trying different things it keept on saying wait 5 min,10min ,15min,and then it went to 20min finally a red screen popped up and said your ipod is disabled please connect to itunes. I have no idea what to do,what do i do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
Here is my answer from a similar question Why wont the password I set work? from earlier today. Apple says "If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons." Now there is a way to erase the password but I am not sure if this would work when you are already disabled. I guess you can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared, again not sure if it works for a disabled one. Just thought of something else. Make sure you have your library backed up.
Also check what Apple has to say about that on here http://support.apple.com/kb/HT1808
A restore on the other hand will return the phone to its default settings and YOU WILL lose all information. You should only do that as a last resort and only do it on the computer that you normally sync with. That way it should restore the last backup. Check on here for directions on how to do that.
The only other thing would be to put your iPod in DFU and restore, again YOU WILL LOSE all data since the last backup.
DFU Mode
Connect your iPod to your computer
Turn your iPod Off
Press and hold the power button for 3 Seconds
While continuing to hold the Power button, press the home button as well for 10 seconds
While holding down the home button, release the power button for another 10 seconds
iTunes should now detect the iPod in recovery mode, press OK, and restore your iPod. you may now release the buttons. If you have not reached this point, then you have not entered DFU Mode DFU Mode Good Luck and I hope this will help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I am facing the same problem as well. I tried both methods but none worked. Mine is a 2nd gen iPod touch.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my ipod A1288 has been disabled unfortunately i dont have the computer where it was sync with itunes how could i fix my ipod?please help me..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
how do you unlock you ipod without a computer or iTunes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rebecca Nohava さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 3,076
