メインコンテンツにスキップ
Appleのメインストリームとなる2020年iPhoneモデルは10月23日に発売されました。6.1インチOLEDディスプレイ、デュアル12MPカメラシステムと5色のカラーバリエーションがあります。iPhone 11の後継モデル。
164回答 すべてを表示
Have I found a way to repair the iPhone 12?
Hi everyone,
i think I’ve found a way to change the iPhone 12 screen as reprogramming the screen doesn’t work. Send the screen to be refurbished! You get to re-use the original apple screen and its a lot cheaper. Let me know what you guys think!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You are assuming you are going to get your exact display back! Most just put your screen in the bottom of the queue and take the completed one from the top!
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
what if I did it at home or suppose that didn’t happen?
さんによる
The part is the issue, not the act of installing it.
さんによる
I mean if i knew the part i was getting was the part i sent, for example if i refurbished the screen at home
さんによる
Some have tried many have failed, Think of it this way just because you can shoot a basketball when you are a kid after weeks of practice, its another after you've walk away from it 10 years later are you going to get it in the first time? Not likely! This gets into how often you do one and how damaged the part is and lastly your tools.
In the end its just not economical to do a few a week as well as your skills in do it. Maybe a few hundred it makes sense. And expect to need to replace one every 25 or so.
さんによる
コメントを追加
回答を追加する
Ifixphoneslol さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 335
