メインコンテンツにスキップ
Repair documentation and service information for Hisense televisions.
143回答 すべてを表示
TV will not turn on
Last night my TV decided to go out, so I finally look at it and the red light flash 3 times and the tv never comes on but when I look closely I can see the Hisense logo pop up and then it’ll fade out.
it will continue to reboot over and over
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
What model tv is it?
さんによる
コメントを追加
2件の回答
The Model is 58RGE
Hisense 58” Roku tv
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I advice you to Why won't my television power on. It is not the same model as yours but most of them seem to work the same.
To recap some of the key points form that post and general advice:
  1. unplug everything including the power cord. Wait a minute and plug the power cord in and try if the tv works.
  2. If it doesn’t work see if you have warranty from Hisense or the store you bought it from. Even if you do not have warranty you can contact Hisense customer service and ask if they have a solution.
  3. If that doens’t work you’ll have to find a solution yourself. It seems most likely to be a power source problem or backlight. This means taking your tv apart and finding out if you can repair it.
Of course you can always come back here with additional questions on repair if that’s what you end up doing yourself.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Devonta Gardner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 229
