メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung 製コンピューターモニターの修理ガイドとサポート情報。
Samsung C32HG70 horizontal lines
I brought a Samsung C32HG70 a few days ago ( no power and when it was had the vertical lines until warmed up issue). I’ve manager to sort the power problem and also the vertical lines, however the panel has horizontal lines across the whole screen anybody have any ideas on what it might be? Included couple of pics running the Xbox Series X on it today.
画像
画像
Update (02/08/2021)
I’ve had the back off the panel again and it seems to have a small 3mm split in one of the lvds that connects it on the lcd panel at the bottom, could this be causing the issue?
画像
like circled in the picture here.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
had the same problem, remove 2 smd resitor and mine was fixed.
if u have the one with 4 resistor and the rt6820a just remove the 2 ones that are vertical farther away from the controller.
Update (04/29/23)
画像
like so
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What function does rt6820a perform? I can't find the datasheet. In the LCD monitor, the chip heats up to 150 degrees and turns off. I can't find the reason.
さんによる 共有
Removing the resistors you showed was not a solution for me, but I discovered something new. The process I have done is available in the forum here. I had to use your photo, I didn't have a clearer photo, sorry.
Link: https://www.technopat.net/sosyal/konu/ms...
さんによる 共有
コメントを追加
@coys77 yes. Those are the ribbon cables coming of your driver boards. Any damage to those will manifest itself by errors on your display.
Those ribbon cables are connected via a special process (TAB) which makes it almost impossible for a DIY repair. You are most likely in need of a new panel.
Old question and this is just to clarify things.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Horizontal or a vertical lines on your LCD display usually indicates a bad LCD display (the panel itself has a very "partial", or "localized" failure). You can try with another screen to see if the issue insists. Or check out the post - How to Fix Vertical Lines on Monitor.
If it is the hardware problem, you’ll have to replace the screen.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thanks for the reply, added a quick update to the question.
さんによる 共有
@coys77 You're most welcome.
さんによる 共有
さんによる 共有
コメントを追加
I had the same problem, I removed 2 smd resistors and mine didn't resolve, there are still horizontal stripes at the bottom of the screen, of course until it warms up, then it's ok, maybe some idea
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@jozsefszenasi what exact model is your TV? Which Resistors did you remove? Post some pictures with your question so we can see what your TV shows you. iFixitでの質問に画像を追加する方法
さんによる 共有
コメントを追加
回答を追加する
Karl C さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 88
今までの合計 4,194
