メインコンテンツにスキップ
Released on July 21st, 2018, the Huawei Nova 3i is an Android smartphone manufactured by Huawei, a Chinese multinational technology company.
17回答 すべてを表示
Help! I've dented my phone battery
While fixing my phone , I accidentally made a small dent at the top-right corner of the battery. Its almost unnoticeable. After multiple streak of bad luck I decided to let a professional fix it.
He said that the battery started to expand(it is said because I played while charging[which is true]).
I’m a bit paranoid so , did the small dent cause it to expand? and/or is it safe to use for at least 3 month?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
If the battery has started to expand it is not safe. You need to replace and dispose of the damaged battery and get a new one.
Those batteries can explode and/or catch on fire and should be handled with great care.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
m-4310002 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 16
今までの合計 469
