How do I reattatch a joycon rail
so i broke off my right joycon rail and have no modding experiance
Depends how it’s broken. Did you drop it? Or pull it? If the rail is still intact, you have to carefully open the Joycon, put it back and close it. For that you’ll need absolutely a TriWing (Y head) screwdriver.
If the rail is broken, you’ll need a new one.
Same thing if it’s the rail on the Switch’s side.
このアンサーは役に立ちましたか?
How do I put it back in?
@Tgw Gaming We can't give you an answer without knowing just what's broken. Is it the rail on the joycon, or the rail on the Switch?
The rail on the joy con
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 267
Depending on how you broke it you might be able to but it back on. Is it possible you can attach a photo of the joycon?
Bri さんによる
same problem here. are the two flat cables from the rail intact like mine are?
Hamm Khan さんによる
