メインコンテンツにスキップ
9月20日にAppleが2019年に販売したiPhoneは5.8インチのOLED、3つのカメラがつき、バッテリー駆動時間が大幅に増加しました。iPhone XSの後継機です。
148回答 すべてを表示
Display is always dimmed
Has anyone seen an iPhone 11 Pro display that is very dimmed? It has around 1/3 brightness compared to my own iphone 11 pro max when I set brightness on highest.
I reset the user settings to be sure it wasn’t a setting. The disply is already dimmed when you see the apple logo when booting.
the phone was dropped and I replaced the backcover and cameralens on it.
When I put another refurbished i11 pro display on it the brightness is fine. Have not seen this before on an iphone OLED. Faulty screen after drop I think but asking to be sure if anyone has experience with this.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Since you already troubleshooted with another device, the problem clearly seems to be in the screen or in the components attached to the screen. Brightness is controlled by the ambient light sensor in the screen, it could be that this sensor is damaged and it’s sensing “darkness” so it would dim the brightness of the screen backlight to not blind you while being in the dark.
If you’re up to it you can try to swap those two parts of the screens you have and see if that fixes the problem.
Have a look at step 26 of the iPhone 11 Pro screen repair. Note that this will require you to swap out the whole speaker & sensor assembly of the screens.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The components don’t matter in this repair. The sensor has nothing to do with how bright a display can be at max. The screen has problems that I haven’t seen before on an iphone oled. Thought it was strange. Swapping it solved it.
さんによる
Then it might be a LCD driver issue or some kind of other damage that isn't to be seen with the naked eye.
さんによる
コメントを追加
回答を追加する
KWH さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 138
