accer inspire it is saying no bootable device
hello i have accer inspire it is saying no bootable device and now i follow all the step but they is no option of legacy on my option
If you are getting a “no bootable device” error, then your computer cannot access either Windows or the entire hard drive. Since you were able to get into you BIOS to see that there is no legacy option, try removing any USB drives that are attached to the computer and boot into BIOS again. Go to the “Boot” tab and make sure that your Windows installation is first on the boot order list. That will force you computer to boot from Windows.
If you can’t find the “Windows” option in your computer’s boot order, then try installing Windows. You can download Windows from https://www.microsoft.com/en-us/software... and create a bootable DVD or USB with the downloaded file.
Then, attach the bootable DVD or USB to you computer and turn it on. The Acer will automatically boot from the USB or DVD and allow you to install Windows on your hard drive.
If there is no hard drive at all, then you may purchase one and install it. Hopefully your model is on the list at Acer Aspire Laptop; the instructions on how to replace the hard drive may be found on this site.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 10
過去 30 日: 49
今までの合計 4,061
Hi,
What is the model number of the laptop?
What OS is installed, Win 7, Win 8.1 or Win 10?
Is the HDD shown as detected in BIOS?
jayeff さんによる
Latest versions Acer Bios (UEFI) don't have that Legacy option. I ended up returning my Aspire5 to the Acer service center and they reformatted the HDD and loaded everything (incl. Bios and drivers) from scratch (no charges as it was still under warranty). Tip: If you have confidential data on your HDD or SSD you should take the HDD out and get a USB HDD external case (cheap) to reformat the drive(s) on another PC, install the HDD back in your laptop before you give (send) it to Acer for service.
frankwitteman さんによる
