80 series won't agiatate
The washer filled with water and now it won't agitate and makes a clicking sound can't get water to drain either.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try to advance your program a bit and see if that makes a difference with your agitator. If not, there are some cogs (dogs) on the inside of the agitator that will "grab" the shaft and make a connection, These may have wore out. Here are some instructions that might help you out. Good Luck
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 1,021
