メインコンテンツにスキップ
TV clicks but doesn't power on. Main Board or Power Board?
Symptoms:
  • When the TV is plugged in a relay clicks continually in this pattern: click - 10 second pause - click - 60 second pause . It continues to do this over and over again.
  • When the power button is pushed on the remote or the tv: The relay clicks - white indicator LED comes on for 15 seconds or so - LED turns off - 1 second pause - relay clicks. The TV never actually powers on.
What I’ve tried:
  • I downloaded the service manual, and the triage section only covers when you get a red blinking error code, or if there is no power whatsoever. Neither of which apply here.
  • I followed the service manual instructions for diagnosing the PSU board anyway. It seemed fine, but I’m also an extreme novice.
  • If I disconnect the main board from the power board, there are no relay clicks
The buddy who owned this TV told me he took it to a repair shop and they said it was a backlight. That doesn’t make sense to me. I’m thinking maybe main board or PSU board. But I’m not sure where to go from here.
For reference here is the power board
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
It may be the backlights so perhaps you need to rule them out first.
I’m not quite sure with Sony but in some other makes of TV the various outputs from the power board are “monitored” and if the outputs are outside their design parameters the TV protection circuits operate, as named, to protect the TV from further damage.
It is easier to do this if you have a TV backlight tester (examples only) as you can test them without the TV needing to be powered on, by connecting it directly to the feeds on the LED power cable which has been disconnected from the power board.
This eliminates the boards from affecting the operation of the LEDs when it shouldn’t due to one of the boards being faulty, so you know whether the LEDs are all OK or not on their own.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mike Poret さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 16
今までの合計 484
