メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
678回答 すべてを表示
callers say I sound far away or can't hear me
i have an iphone 8 plus. i swapped out the charging port and i have been issues with calls. those receiving my calls say they can’t hear me or it sounds like I am far away. I have looked at different forums and tried sliding the bar on the haptic sound bar. Turned off noise cancellation. The charging port and all other things work fine but this is the one thing left to make my repairs “perfect”. Any help or advice would help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The charge port has two microphones that are used for outgoing calls one of them provides noise cancellation. You might have damaged one during the replacement. If you purchase another one make sure it is an OEM one pulled from an original iPhone 8 plus.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Well I've changed the port twice and nothing has changed. I was wondering about the plastic gasket that goes over said microphones. I am unsure if I put them back in the right way.
さんによる
コメントを追加
the microphone is usually taped and when you peel it off, the adhesive tape can stick to the frame, clogging the hole of the microphone (on the metal frame and not the part itself) when you put in a new microphone, then you have bad or no sound
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
that honestly sounds like something that might have happened. i am sure to disassemble my phone when i have a free day. thank you very much.
さんによる
I've also been there a few times. but it is also useful if you clean the entrance of the microphone with alcohol. it can sometimes just be dirty inside (metal frame)
さんによる
コメントを追加
回答を追加する
Jorge Fuentes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 34
今までの合計 795
