Model #110.66752501 It spins with no load but will not spin with a l
Model # 110.66752501
But will not spin with a load
My question is do they have clutches or a pack of clutches
Hi
The drum is belt driven, so maybe you need to check the belt (part #30 cabinet parts diagram), the motor belt pulley (part #29 cabinet parts) or the dryer idler pulley (part #39 cabinet parts) to see if they are all OK and that the belt has enough tension on the drum and is not slipping somewhere when the drum is loaded.
Here are the parts diagrams for the dryer.
If you find the problem and it is a faulty part then there are other suppliers online that may suit you better. Just search for 11066752501 parts to get results for suppliers.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 39
