メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Whole Keyboard stopped working
Hey! About a two weeks ago I spilled some soda on my Macbook Pro 2015 13”. It really were just a few drops on the top-left side of the keyboard so I don’t think it harmed anything really. (What do you think? The problems started to arise about 1 1/2 weeks after the accident?)
Anyways, a few days ago I saw that my keyboard suddenly stopped working. When it happened, I started randomly typing on it and after about three seconds it worked again for a few minutes. (The WHOLE keyboard stopped working, power button was completely fine though) This happened for a couple of days on and off. Eventually it stopped working completely.
So I opened my machine up to see wether there was any water damage visible. Took the motherboard out, lifted up the “background lights tab”, but nothing. I didn’t see any water stains whatsoever. So I built everything back together (I think I saw that the keyboard cable was a bitt loose when I opened it up, so I put it back in correctly) and it did work again… for one day. The problem arised again, but only very rarely (once every couple hours for a few keystrokes)
So… I did some research. Apperently the power button is a seperate port on the connector, which explains why it worked.
So I am now searching for the broken part and I am not even sure anymore if my soda accident had anything to do with it (It was 1 1/2 weeks ago, the computer was everyday in use and only after that the problems arised. Besides, the WHOLE keyboard stopped working not just individual rows)
I narrowed it down to a broken touchpad-to-mainboard connector or the USB Controller. Floating Ground maybe? Or even missing PP3V3 or PP3V42? Power button still works, and is low active after all, but maybe isn’t as sensitive. Measuring anything isn’t going to work because the problem happens so rarely.
Thank you guys so so much!
Update (20.01.2021)
Here a screenshot from coconut battery
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Lets rule out your battery first, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Well the battery looks OK from CoconutBattery. At this point you’ll need to open things up to see if the battery has become swollen. If it has you’ll need a new battery.
Update (01/22/2021)
@Lukas - If it was the internal USB controller (hub) then your trackpad would also not be working.
It's starting to sound more likely you have killed the keyboard its self with your soda spill. Time to replace the keyboard!
This gets tricky! You’ll need to follow this guide to either replace the full uppercase (easy & quick, but more expensive!) or go deeper replacing the keyboard alone (harder & lengthy, but cheaper) MacBook Pro 13" Retina Display Early 2015 の上部ケースの交換
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I already opened it up. Battery OK. I suspect a broken connection somewhere, although... the whole keyboard doesn't work... maybe the USB Controller even?
さんによる
I'll just keep an eye on it for now. When it happens again I'll open it up and measure the vias on the mainboard. I really want to rule everything out before I change the keyboard. After all, it really were just a few dropplets but then again... It looks like a duck, it sounds like a duck, it probably is a duck. Thank you though!
さんによる
However I have one last question ;) could it be the flex-cable to the trackpad circuitry? The power button works, but the rest doesn't... and the power button is the only one not going to the trackpad
さんによる
@Lukas - Possible corrosion on the logic board connector? You'll need to inspect it.
さんによる
コメントを追加
回答を追加する
Lukas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 45
