メインコンテンツにスキップ
AppleのMacデスクトップもしくはラップトップコンピューター用のオペレーションシステムです。
59回答 すべてを表示
Cant I load Puma 10.1 in vbox
Hello, Im trying to load OS X Puma 10.1 in virtualbox, but it just comes up with this:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The OS-X Puma release requires OS9 to be run concurrently and also will only run on a limited group of Mac systems of the era.
It was mostly a development release than a real consumer release. How about going the newer OS-X/macOS release your system can support. I do recommend getting to Sierra 10.13.x as it is the oldest still supported release but your given system also plays a part here it may not be able to support it.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Im runniing it in a virtual machine
さんによる
@macbookiphone - You still need OS9 loaded to then run OS-X 10.1 as it requires the OS9 resources. It makes no difference how you run it, also the VM needs to offer the needed resources to emulate the older hardware calls as well.
さんによる
do i install OS9 as a vm too?
さんによる
also i am using macOS 10.13.6
さんによる
@macbookiphone - Why are you trying to install an early development development release? There really isn't any good reason I can think of.
If I remember correctly it was OS-X Jaguar (10.2.x) which was the first release that could run stand-alone.
さんによる
コメントを追加
回答を追加する
macbookiphone さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 126
