メインコンテンツにスキップ
HPによるChromebookの修理ガイドならびにサポート情報です。
161回答 すべてを表示
Cannot click on touchpad - only tap-to-click work. Please help!
Hi! I have an HP Chromebook 11-v010nr. The touchpad does not respond to clicks - I can only use tap-to-click. I suspect that it is dirty in there and might need to clean it. If so, how would I open it up? If I were to open it up, would I need to replace any parts? Like the non-slip rubber at the bottom of the Chromebook?
Is there any ways that I can fix it without opening it up?
I would appreciate videos and links to purchasing parts.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
8 件のコメント:
Does it makes a clicking noise ? and Did you tried updating your drivers ?
さんによる
Yes it makes clicking noise. Not sure if the inside is dirty that’s why it doesn’t respond. Haven’t updated driver. Not sure how to update driver.
さんによる
@creazyp154 Yes it makes clicking noise. Not sure if the inside is dirty that’s why it doesn’t respond. Haven’t updated driver. Not sure how to update driver.
さんによる
@Mike Lim Try opening that up on your pc : https://support.hp.com/us-en/drivers/lap...
さんによる
@creazyp154 this is what the website said
We were unable to find drivers for your product.
Try manually selecting your operating system. If your operating system is not listed then HP may not provide driver support for your product with that operating system.
さんによる
3件以上のコメントを表示
コメントを追加
1 件の回答
Ok so it could be an issue with gunk in the sides of the touchpad, try getting rubbing alcohol and a Qtip, or some very small pliers to clean around the outside, if not then you would have to open it up.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike Lim さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 26
過去 30 日: 40
今までの合計 325
