メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Do iPhone 7’s naturally run hot?
I purchased a used iPhone 7 and replaced the cracked screen with a new one. It is in cosmetically almost mint condition now (housing was in very good condition), however have noticed that when 20Watt fast charging it and during use it can get quite hot near the logic board. The device hasn’t been water damaged (indicator is white) and the logic board is in visibly perfect condition with no signs of logic board repairs, and all parts appear to be Apple Original. Any ideas? I have another 7 as a spare that can also get quite hot when playing games so I don’t know if it is just a thing with the 7’s?! Thanks (:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
iPhone 7 doesn’t support fast charging, the best it can do is about 7.5-10w.
Since we can’t be sure of your subjective experience of temperature, all we can do is ask you to get a known good iPhone 7 to compare, if they behave the same consistently, then it is normal.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Okay cool - I will try it against another 7 or 7 Plus if I can’t find one, and will use standard changing brick and see if that works better. Thanks!
さんによる
コメントを追加
回答を追加する
TmG さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 37
