メインコンテンツにスキップ
Device repair and troubleshooting guides for the HP Pavilion 13-s128nr x360, a consumer 2-in-1 laptop by HP released in September 2015.
21回答 すべてを表示
My laptop power button is flashing and it won't turn on
Hey I need help my laptops power button is not working. It first started when I decided to use it was broken but I needed something from the laptop. I had dropped but i didn’t think nothing of it. When I turned it on worked. I needed internet so i went to my living room then it died and when I tried charging it the power button was flashing. I honestly don’t know what to do send help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If the caps light and charge indicator blink, that’s usually RAM with HP laptops. Take the laptop apart so you can get to the RAM and reseat it, as it often helps. If it isn’t loose RAM, you may need to replace it.
The HP service manual can be found here. You need to tear it down to the motherboard on this one to get to the RAM.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Asmier Powell さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 24
今までの合計 1,312
