Is the headband replaceable?
Apple has anticipated replacing the ear cups but I really wonder about the head band. There doesn’t appear to be removable and seems like it will wear out rather quickly.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There’s a pin hole you can stick something like a SIM ejector tool into that will “eject” the headband. It feels replaceable.
このアンサーは役に立ちましたか?
I've looked closely but I can't see any pin hole. Do you have to fully retract the head band or something? Any hints on where to find it?
Remove the cushion, fold the headphones flat, and then there is a tiny hole centered at the top of the plastic where the cushion was. I circled it on this teardown photo: https://imgur.com/a/zJ8DiLa
All of their products are designed with forced obsolescence and as little reparability as possible in mind. And their whole line of Airpods are no exception.
このアンサーは役に立ちましたか?
That doesn't really answer the question.
@Zachary Whitley have you ever had an apple product serviced by apple? Call them up and ask if the head band is replaceable. They are the manufacturer after all so they should know what's best.
Just exactly THIS AirPods is different from the other ones. Would you mind reading the teardown? Its surprisingly interesting how these headphones are done!
These AirPods are very repairable.
I’ve checked with Apple Genius Bar and unfortunately Apple is currently unable to offer replacement headbands.
このアンサーは役に立ちましたか?
Is there any third party headband I can use? Apple doesn’t provide this spare part.
このアンサーは役に立ちましたか?
過去 24時間: 6
過去 7 日: 47
過去 30 日: 165
今までの合計 3,169
