My Mac doesn't boot cuz I wash the motherboard with petro.
Hello,
I mistakenly wash my MacBook Pro 13 mid 2012 motherboard with petrol instead of compressed air. Now the mac doesn't boot. Please what can I do?
Time to find someone with a large enough ultrasonic to hold your board. You want to use a variable frequency unit as it will be able to more effectively remove the petrol.
You’ll need to use a solvent which can cleanse the petrol which is non flammable and don’t have dangerous vapors in the ultrasonic.
You may need to research and experiment a bit to figure out what you can get. If you can’t find anything thats non flammable use the ultrasonic cleaner outside and have an fire extinguisher handy just in case!
Otherwise its time to replace the logic board.
このアンサーは役に立ちましたか?
Pretty much your only options are to replace the whole board or do as danj mentioned
…Wonder how did this even happen?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 54
