メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
LGによって製造されたAndroidスマートフォン用の修理ガイド
2434の回答 すべてを表示
How to replace broken LCD on LG Cosmos Touch (LG VN270)?
Hi,
I recently got a LG Cosmos Touch (LG VN270) for my upgrade and the screen has broken on it. Everything else works on it, antenna, digitizer, vibrate motor, etc., but the LCD. I do not have insurance on it so I would like to try and the repair myself as to save a little bit of money. The problem is though, I haven't the slightest clue how to get the phone apart and replace the LCD. The closest I have gotten was getting to the motherboard. After that, i have no idea how to get to the screen. If anybody can give me some guidance it would be greatly appreciated. Tips, suggestions, full tutorials, anything! Just help shed some light on this project so i can continue to use my phone.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
i have the EXACT same problem right now.!!!!:/ i jjust dont know what to do. it is being soo weirdd.!! like if i open it and type in a numberr(of course you cant see anything on the screen but blackness) i can STILL call people and talk to themm.!! its sooo weirdd.!! sorry i couldnt helpp,....just thought i would share some of my concerns and emapthy for youu.!!:)
さんによる
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
3件の回答
最も参考になった回答
You can download the service manual for your phone from here. It does have an excellent explosion diagram that will show you how it is all located. Of course it has a whole bunch of other info too. The lcd is available at places like this, and many others I am sure. Just do a good Google search and see what you can find that you like.
この回答は役に立ちましたか?
スコア 1
コメント:
Hi Turk03: Could you enable the above referenced link on your share site? I'm planning to take a whack at a repair job, and would like to see your diagram if possible. Thanks!
さんによる
It should be there :-)
さんによる
Hiturkey03 Can you enable link on your share site .Thanks verizon24
さんによる
william, here it is
さんによる
Hello oldturkey, could you share with glory13666 as well?
さんによる
9件以上のコメントを表示
コメントを追加
Turn the phone off
Remove back pannel
Remove battery
Unscrew 6 screws
Take off the piece of plastic covering keyboard and motherboard
Then there will be a cable for digitizer/lcd unplug
After that there will be more screws
Sorry not sure how many
Then take off the piece of metal
Unplug another cable
Slowly, Steadly, Not to hard push upwards to remove old screen
Then apply new one put everything back together, and add the screws back in.
Put the battery in, and batter pannel, turn that on, now your phone works like new, and works like a brand new out of the box...... XD
この回答は役に立ちましたか?
スコア 0
コメントを追加
It is not necessary to remove the 4 black screw to remove the LCD panel. I found this out after stripping the head on one and having to figure out a workaround. :) Thanks for the info on this.
Also, unfortunately, this did not fix my touch screen problem... :(
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hank Kuhsel さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 7,690
