メインコンテンツにスキップ
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
48回答 すべてを表示
No battery charge light, but battery reports 100% yet doesn't work
Slightly different than what others have been experiencing. No battery charging indicator light illuminates when plugged into AC power. Battery reports 100% on the indicator and shows good charge after running a battery report…so it seems like its recognized — yet when I try to use it without AC power the computer immediately dies. I’ve tried the uninstall battery method and it didn’t work. Neither did leaving it plugged in to trickle charge. I tested the power at the battery connection point on the motherboard. Without battery attached but AC adaptor not plugged in, I only got one reading: pin 7 at 3VDC. With the AC adaptor plugged in I got readings on pins 3 and 4 of 2.7VDC, pin 5 at 0.4, pin 7 at 3 and pins 8 & 9 at 0.7VDC. Worried that its a mobo problem vice a battery problem but looking for any suggestions. Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
laptop toshiba in no battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Denny さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 7
今までの合計 80
