メインコンテンツにスキップ
2020年4月に発表、発売された第二世代iPhone SEの修理と分解情報です。
236回答 すべてを表示
Replace iPhone rear camera?
Can I replace the rear camera on iPhone se 2020 2nd generation without disconnect the battery and without seperating phone! This would be my 1st attempt doing this! Phone was ran over screen replaced but back cam is cracked and blurry
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
:-) Greg!
no, you cant’t do that! We have been talking for years about the fact that replacing ports from “block type” to “plug type” forces certain behaviors ... including the need to disconnect the power supply to CONNECT connectors. You can always do it at your own risk, but don't write later in your posts that it "fell and didn't turn on". If you don't feel like plugging in the batteries, unscrue or taking the motherboard out when serviceing, maybe you should take that to a good repair shop. They will certainly do it right there.
It's a pleasure to repair your own device. Repairing someone's device is primarily a responsibility.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks for your reply I was just wondering I’ve never really worked on a phone but I can’t afford to pay someone so I figured I’d try myself ! I’m pretty good with fixing stuff myself , but I know these parts are delicate!so I don’t wanna disconnect it and not be able to get back in place
さんによる
Greg,
Make a copy of your data - as a first step. Unscrew and remove the screen screws, take off the screen. Then the bracket screws and disconnect battery and screen. Watch out for the tapes. Then remove the rear camera. That's all. Put everything in reverse order. Don't forget - this is important: if the system (I do not know what version of IOS you have) does not accept the new camera, perform a DFU recovery (necessarily).
Done :-)
さんによる
コメントを追加
The Camera is not paired to the phone. Camera can easily be replaced. Anyone that says different don’t know anything about repairs.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Greg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 190
