メインコンテンツにスキップ
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
93回答 すべてを表示
want to drop pan change sensor and selenoid
Yes thank you.
Question:
123000 mile 4.0 G. Cherokee just want to drop pan change sensor and selenoid. Told I should not . Because it's never been changed. But I don't want to flush and drain all just what is left it's almost dry. Have to try and do my self. 500 plus bucks mechanics in ny asking. Trying to rip off a woman. Especially during these times and it's cold.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@jeepgal exactly what is it that you are trying to change? This "want to drop pan change sensor and selenoid." confuses me a bit. You know we can help you just need to know what it is exactly that you want to change.
さんによる
コメントを追加
1 件の回答
I assume you are talking about the transmission. You need to see if the fluid is burnt. If the fluid is burnt and you take the pan off and put new fluid in it it is most likely that the transmission will go out. What solenoid are you talking about? What is the problem you are having?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sus さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 30
