メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Galaxy A71は、Samsung ElectronicsがGalaxy Aシリーズの一環として製造したAndroidスマートフォンです。2020年1月に発売されました。 バージョン:SM-A715F/DS、SM-A715F/DSN(グローバル)、SM-A715F/DSM(ロシア)。
Suspended logo samsung a71
This A71 of mine has been in use for quite some time and has recently had lag and has had a logo on it today. I don't know how to handle it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @akahuyhoang ,
Things to try to resolve the problem:
a). Wipe the cache partition and check.
b). Start the phone in safe mode and check if this improves the performance of the phone.
If it does then a downloaded app is the cause of the problem. The trick is to find out which one it is. You will have to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall. When it works OK then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you installed on the phone and did not come pre-installed on the phone when you got it.
c). Try a factory data reset (aka hard reset) and check.
Be aware that a hard reset will erase all your data and downloaded apps. It will restore the phone to its factory default (or last system updated ) condition. If you decide to try this back up the phone to the cloud or a computer before performing the reset. Also if the phone has a Google account remember what the User name and password is for the account as you will need it to access the phone once the reset has been completed. (Google FRP lock)
Once the backup has been completed, make sure that the battery is fully charged and then perform the reset.
Once the reset has been completed (be patient it takes a little while to complete) check if the phone now works OK i.e. no lag etc. If it does then using the backup that was made earlier, restore the phone using the phone’s restore feature (check in Settings).
Once the phone has been restored to what it was, check that it still works OK. If it does then the reset has resolved the problem.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
akahuyhoang さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 342
