メインコンテンツにスキップ
2.3L 4cyl or 3.0L V6, 6th Generation
426回答 すべてを表示
Why wont my cat start after running out of gas cranks no start
I have a 2002 honda accord I ran out of gas one day filled the tank half way my cranks but wont start. Fuel pump turns on fuses are good getting gas up to the fuel rail not sure if theres a filter under the hood if so can not locate it any ideas would help please
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
When I ran dry, I needed to turn it from off to on 4-5 times (each time waiting for about 5 seconds at on), to get the fuel up to the engine. It then took a bit to crank, and then fired up.
With it running out of gas, some sediments in the fuel tank may have been introduced into the fuel pump, and be lodged in the fuel line, or worse at the injector. (Although unlikely with a filter)
I did find a video for the fuel pump/filter, may want to check it: https://www.youtube.com/watch?v=zW5_enbk...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jimmy Boner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 57
