メインコンテンツにスキップ
2019年3月に発売されたA12 Bionic チップ、10.5インチスクリーンのiPad Air です。
39回答 すべてを表示
Does the iPad Pro 10.5” lcd work on the iPad Air 3rd gen?
Hi all,
as the title says, does the iPad Pro 10.5” lcd work on the iPad Air 3rd gen?
I have an iPad Air 3rd gen in for repair which the customer had told me was an iPad Air 1 so don’t have the lcd display for that model in stock but my local supplier has iPad Pro 10.5” screens in stock and are cheaper than the iPad Air lcds.
I have a separate iPad Pro 10.5” digitiser which when connected to the iPad Air 3 works fine but don’t have the lcd to test.
thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
iPad air 3rd gen and iPad pro 10.5 screens are identical there are no differences between the two display panels. The iPad air 3rd gen is locked at 60hz by software not hardware so yes an iPad air 3rd gen display would work fine on an iPad Pro 10.5 and vice versa. Also if you plug in an iPad Air 3rd gen display on an iPad Pro 10.5 the refresh rate of 120hz is available as both iPads have 120hz display panels. Like I said the Air 3rd gen is software locked at 60hz.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Although they may look the same and even have the same connectors, I don’t believe they are compatible. Most if not all Pro models have a higher refresh rate so that may cause compatibility issues.
For the future, I would confirm the customer has the correct model by asking for the A number. If I have to special order parts for anything, I take full payment up front and contact the customer when they come in.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I’m no expert, but it sounds like it wouldn’t work because apple’s screens in general are usually programmed to the specific model. Even if they had the same connectors, it probably wouldn’t work. Plus, an iPad pro’s display supports 120hz while the iPad Air is locked at 60hz
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mwr_allen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 50
今までの合計 1,689
