My iPhone 6 when it try to charge it seems charging in phone. But not
When my i phone 6 try charge it seems charging in screen but not charging and it is restarting automatically in some times?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You should replace the battery to begin with. If it is still acting the same let us know.
このアンサーは役に立ちましたか?
Baterry is new one
@Namshil muhsin Ck This is commonly called false charging. If you have ruled out the battery it can be caused by a faulty battery connector or charging IC. The most common is a faulty Tristar IC which will require microsoldering to replace. Since it is an iPhone 6 I would suggest an upgrade.
Thanks.
If faulty tristar ic. Cost is too much for replace?
@Namshil muhsin Ck Around $90
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 35
