iBook G4 has bad airport card. How do I disable airport
I get a kernel panic when iBook boots up. I think it's a bad Airport Card. How can I disable airport in safe mode?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Open your system preferences, go to Network and turn it off.
このアンサーは役に立ちましたか?
Thanks Mayer, but I get the kernel panic on boot up, so the only way for me to access the iBook is in safe mode. Airport is disabled there and grayed out in Network pref's. I know there must be a terminal command to disable it. I'm thinking I can just disable the airport card and buy an wireless USB adaptor...
I am in Tiger
Out of curiosity, reboot the iBook while holding down SHIFT to get into safe mode.
Does it still kernel panic?
Restart OS X normally. Does it still kernel panic?
If so, have you considered physically removing the Airport card?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 488
