How do I open the case containing the buttons and the mic?
As the cable was bit off by the cat nearby the remote part, i want to check out if I can fix it somehow.
この質問は役に立ちましたか?
The Apple Earphones with Remote and Mic have all the performance and comfort of the acclaimed Apple iPod Earphones plus convenient buttons that let you adjust volume, control music and video playback and even answer or end calls on your iPhone.
Depending on how much excess wire you have left, you could always splice a new pair of headphones into the controller. Of course, you'll need the TRRS (tip ring ring sleeve) connector for it to work.
コメント:
dude, exactly, how do you open the case without breaking it, so you'll be able to put it back together?
by HoZi
the back of the remote just pops off if you can slip a fingernail in there. or mine did. but my remote has been quirky since week two of owning it so maybe its just me. the back is held on with two sets of two tiny clips, should be easy enough to remove.
by Rae Dragon
Thank you Josh !
I'm adding and image to show how are the clips that holds the back in place.
The metal plate is glued to the back, so I've added some to hold it again in place.
It was impossible for me to add it rotated. You can find it as it is in this link:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 10,943
