Hi @kcat0109 ,
Check that the compressor is not getting too hot when it is operating and is being shutdown due to over temp. Be careful not to burn yourself. Compressors are designed to run for long periods of time and may get warm to the touch but not hot.
Here’s a link to the section of the service manual that shows to to perform the various load test diagnostics for the refrigerator.
Also this shows how to test all the sensors,in case one of them is causing the compressor to be told to stop.
Depending on the results shown the following pages may indicate what the problem is.
Hopefully the manual will help you to find the problem.
Hi @kcat0109 ,
Not sure what you mean when you say “Only thing that shows is a couple of lines. Top horizontal line and bottom a vertical line.”
As there were no error codes then I’m assuming you mean this is for the diagnostic load test as per p.77 of the manual, is this correct?
If so which two lines do you mean?
Here’s the image of the display from p.77 can you describe which ones they are i.e. R1 a-g or R10 a -g or F1 a-g or F10 a-g
An example would be R1a or R10a for the top horizontal line and F1f & e for a bottom vertical line.
On p.78 it describes what all the LED segments mean
(click on image to enlarge for better viewing.
2 件のコメント
I just bought this refrigerator two months ago new I should not have no problems
Roxie Q Lawrence さんによる
@roxieqlawrence
If the refrigerator is "new" i.e. you have been the only owner, and not bought "used" i.e. 2nd hand, then contact the Samsung customer service department in your location and make a claim for a manufacturer's warranty repair.
jayeff さんによる
