メインコンテンツにスキップ
An external optical drive by Apple, essentially a rebranding of the MacBook Air SuperDrive.
35回答 すべてを表示
Can not find Super Drive in Finder or Disk Utility.
Super Drive was recently plugged into a non apple laptop (did not work). When I tried to use it in my MacBook Air using Satechi Aluminium USB-C Multiport Pro Adapter it says USB Accessory needs power. (It worked before) Can the Super drive be fixed or is it best to just buy a new one??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It might be repairable! It depends on your skills and getting access to the needed parts.
When you plugged it in to the other systems USB port you some how damaged the logic (I wouldn’t use that systems USB port as it could damage something else)
Here’s a guide which will get you in and access to the logic board Apple USB SuperDrive Optical Drive Replacement
Checking the discreet SMT devices is about all you can do unless you can get a parts unit to swap out the logic board.
Otherwise you’ll need to get a replacement drive.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you for the quick response. I’ll try this and if it doesn’t work for me I’ll replace it.. Thank you xx
さんによる
Don't forget to accept the answer - Thanks!
さんによる
コメントを追加
回答を追加する
Terene Sinckler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 297
