iPhone 11 pro not included
Hello, the phone is obviously dropped and does not turn on. what is its problem circuit board or battery.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you did have vibrate on mute enabled, you can perform a quick and easy test. Simply flip the mute switch. If it vibrates then its obviously not the battery because it is powered on. You could also try to call your number. If it rings then again, it’s powered on. If you dropped it you most likely damaged the OLED panel.
このアンサーは役に立ちましたか?
Thanks for the info will work. ;)
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 258
2 件のコメント
have you tried a replacement screen at all?
Jade Richards さんによる
I'm not I thought it was the battery
dimit1r89 さんによる
