メインコンテンツにスキップ
Googleの第三世代Pixelラインのスマートフォンです。初めての”ノッチ付き”スマートフォンです。6.3インチ QHD+ OLEDディスプレイ、64もしくは128GBの容量。Nearly White、Just BlackもしくはNot Pinkのカラーバリエーションがあります。
77回答 すべてを表示
What are two parts near battery port on motherboard? One of them broke
What are two parts near battery port on motherboard? One of them broke ? Do we have to solder or glue can work ?? Will it cause any power or display problems ??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント:
Thanks a lot Josh for replying. But the one I am posting is not on back cover and is actually on frame near to battery port on motherboard where you plug the battery on the motherboard
さんによる
@nagraj I understand that, but gold contacts have two contact points. The picture I pointed out is the other contact point to the contacts you posted. Does that make sense?
さんによる
Oh ok got
But what does that do ? And if it’s broken what is the solution
さんによる
Looks like they are just grounding pins in case of an electrical surge. There isn't really any need to fix these, they aren't quite important, but if you did want a fix, it would be as simple as just bending the pins back, as they look bent but not broken
さんによる
コメントを追加
1 件の回答
Those are gold contact points for the rear cover of the phone, not sure what they are used for, as the fingerprint sensor is not connected to that in any way.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This will not cause any problems in short but these pins are used as a grounding function to help not short out any components incase for any electrical surge throughout the device
さんによる
コメントを追加
回答を追加する
Yatiraj Sharma さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 68
