Can just the glass be replaced?
My LCD is intact and just the glass is broken. Can the glass be replaced and how difficult is it to do if so? I’ve replaced screens and batteries in iphones before.
hello Blake,
air3 has integrated matrix, touch level and glass. Cost is circa 130$ if you can change it yourself. You will need a adhesive gasket (3-4$). That is all. Cost in repair shops is about 200-250$. It is not more difficult than replacing the iPhone, but due to the size it is time consuming.
I hope that I helped, regards,
この回答は役に立ちましたか?
Air 3 has laminated/fused LCD and digitizer, tools needed to separate and rebond them are not cheap, it’s more economical to buy the screen assembly from a reputable vendor like MobileSentrix/iFixit/InjuredGadgets etc.
この回答は役に立ちましたか?
過去 24時間: 2
過去 7 日: 17
過去 30 日: 98
今までの合計 561
