Can the iPhone 4s camera be installed in the iPhone 4?
Just as the tittle says.
Can the camera be installed on the iPhone 4 to "upgrade" the camera?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Just as we expected, the connector for the camera on the iPhone 4S is different than the connector on the iPhone 4 (CDMA and GSM). This means that you cannot "upgrade" your camera in your iPhone 4 (or downgrade your 4S if for some odd reason you can't handle the 8 megapixel camera). The iPhone 4S connector has more pins. Even if it did fit, I don't think it would work anyways.
iPhone 4S:
iPhone 4 (CDMA and GSM Side-By-Side):
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 3,245
3 件のコメント
I think it will be different since they changed it quite a bit. We'll check that out when we do our teardown.
Scott Head さんによる
agreed, too early to tell. from what I know about apple components, most likely not.
hectordtruong さんによる
Do you know who the manufuacturer of the camera is? The world is waiting...
bob cooper さんによる
