メインコンテンツにスキップ
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
53回答 すべてを表示
Where is the egr valve located on 1998 mazda 626
where is the egr valve located on 1998 mazda 626
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Thank you for accepting my answer and good luck to you.
さんによる
コメントを追加
1 件の回答
ベストアンサー
It's underneath the throttle body. Round in shape, has an electrical connector for the EGR lift sensor and a vacuum line is connected to it. Check the attached diagram. I would definitely clean it first and make sure that your vacuum lines do not have a leak before replacing it. No a common part that wears out. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Tom Mullis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,994
