hard drive raplace whit ssd
Can I upgrade my hard disk raplacing it whit an SSD only following the replace hard drive's guide on ifixit?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sure, just make sure to use the jumper pins to take it down to 1.5 GHz if disk utilities won't see it.
このアンサーは役に立ちましたか?
The 2010 EFI and up should support SATA 3 & 6, there should be no reason to take the disk down to 1.5GBs with the supported operating systems for this model.
Hey AB he said IF disk utilities doesn't see it. Probably won't be a problem but that's the cure if there is one.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,334
