メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
872回答 すべてを表示
Why is the smart battery case not working?
Hi community first post here! I have recently bought an Iphone 8 and I had a smart battery case for my Iphone 6s before. I read everywhere that this case works with iphone 8 even though apple says it doesn’t support it. When I connect it to my phone it doesn’t work, doesn’t even charges it’s like nothing’s there. DO anyone has any experience with this? Since I bought second hand do you think it might have something to do with some parts being replaced? Like battery or lightning connector?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I’m assuming you purchased the iPhone 8 second hand? That phone should support an accessory like that however there may be some caveats. There’s a USB validator chip known as TriStar or Hydra depending on the model (I believe Hydra is in the X and above). Anyways these chips check to make sure that whatever you plug into the lightning port is safe to use and won’t cause harm to the device by talking to another circuit chip located in the device you connected. A good quality accessory will have surge protection built in to ensure no harm is done if something goes wrong. However, cheaper accessories will “trick” TriStar and cause harm. If you purchased that iPhone 8 second hand there could be a possibility that it had some underlying issue.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Yes it's second hand, I'm going to check with the seller to see if they can find a solution! I'll post here if I have news.
さんによる
コメントを追加
回答を追加する
joaopfss さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 536
