メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1623回答 すべてを表示
Unable to start internet recovery nor unable to install fresh OS
Hi Folks,
Good day!
I have a macbook pro mid 2012 13” which was earlier running Mac OS Sierra in a hdd. I then decided to upgrade to an ssd and since I dont want any back up, I thought to install a fresh OS in the SSD.
I successfully installed the ssd (Crucial BX500 240GB) in the optical drive slot (where my previous hdd was planted).
I had a bootable Seirra OS in a pendrive, so I tried to boot the mac os via pen drive. I was successful in reaching the menu to access Install OS, Disk Utility menu. From the disk utility, i was able to see that the mac has detected my new ssd. So i did an erase and then created two partitions of 240gb each. Then I tried installing the os from the bootable usb. It was successfully going till the last (took around 45 mins) and at the last it throwed an error: ‘This copy of Install Mac OS Seirra application has been damaged and cant be used to install mac OS’
So with no option left I tried to do an internet recovery but I got stuck in the spinning globe with wifi selection screen: even after putting the password it kept spinning for 15 mins and then threw a 2002F error.
I googled and saw that this error is due to connectivity issue. I use a high speed internet that gives 60MBPs speed. I tried changing dns as advised but no use. Can some one say me how to install the mac os in my newly installed ssd please?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I’m suspecting you have a bad HD cable! Here’s a bit more on the issue Your Hard Drive Cable Is A Ticking Time Bomb. Here’s the needed part MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable and here the guide MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cableの画像
製品
$34.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Avinash™ Kumar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 71
