メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Tahoe Limited Editionを除き、この車両は2000年モデルで、フルサイズピックアップトラックやSUVと共通の新しいGMT800プラットフォームに基づいて再設計されました。
Why does my brake pedal go to the floor when the engine is running but
when the engine is running, my brake pedal goes to the floor. when engine is off, I can pump up the brakes somewhat. I have changed the master cylinder and there is no fluid leak. Could the problem be with the power assist boost, or is there something else that could be the issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
My brake pedal go to the floor it stop the car but with the pedal tolow
さんによる
Hi I have a 2004 dodge dakota,Replaced (rear break lines rear rotors ,calipers,pads front calipers ,pads ,master cylinder, and brake booster.Bled out all air have a good hard up top pedal when truck is off .As soon as started pedal goes to the floor ? Why why ? Also the new booster check valve has three holes the old one only two.??
さんによる
Same here mk4 bora nightmare spongy brakes im on the edge of a meltdown here 😢
さんによる
コメントを追加
3件の回答
ベストアンサー
Hi @kyvic,
What is the model year of the vehicle?
I don't know the vehicle but reading online it seems that it may have either a vacuum brake booster or a hydraulic brake booster given what booster part types are available.
If the brake pedal sinks to the floor when the engine is running then there may be a problem with the brake booster. Here’s a video that may be of some help for a vacuum brake booster. At 3:30 minutes into the video it describes why the pedal may go to the floor - faulty poppet valve in the booster.
Here’s a link that details how to test if a vacuum brake booster is working properly.
I don't know about a hydraulic brake booster but here’s the 2007-2009 GMC Yukon Service Repair Manual + Owner’s Manual. I realize that this is out of the model year range that you selected but in the Brakes > Hydraulic Brakes section, it describes the operation and repair of the hydraulic brake booster. Hopefully it may be the same for your year model.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I have a 2000 ford excursion gas engine. I have been battling trying to bleed the brakes. I have dumped 4 gallons of oil through the line. Changed calipers, checked vaccume lines, the pedal gets stiff while pumping but goes to floor when starting. Still cannot get air out of lines. Is there another way to test the booster that I can do? So far everything seems good. Cannot find a leak anywhere. I don't loose fluid while it is sitting, or while I pump the pedal. I do not have a scan tool to activate the abs but scan tests good. Any help would be great. I don't have the money to have towed to a garage and repaired. Thank you
さんによる
Not sure if directly helpful to you but perhaps to other ford owners: forscan is a free app that supposedly has a brake bleed component
さんによる
コメントを追加
A brake pedal going to the floor could be indicative of having air in the system still. These can be notoriously hard to bleed all of the air out. The air will get trapped in the ABS pump and will give you a dodgy pedal. I have found activating the ABS system will help to shake the air out. There is a special bleed procedure dealers perform with their scan tool in order to activate the pump. You CAN, although I do not recommend, find a place to jam on the brakes to activate the pump and then rebleed.
If you cannot get a pedal at all, make sure you do not have another leak still, some can be harder to find as they will spray higher up or dribble along the pipe and not drip. If you got a refurbished or used M/C I would double check it to make sure its not internally leaking. They can also leak into the booster hiding a leak.
good luck
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
,,, whilst searching for a solution (however not yet found) my mechanic disconnected the master cylinder from 'under the bonnet' feed and fitted 2 bolts instead to tke master cylinde, psdal was tight and didnt budge, therefore eliminating the possibility of air bubbles - nof surs if this helps.
さんによる
How would u do this at home? I'm dealing with this brake issue and it's frustrating... My first time doing them on my own
さんによる
@Zykearia Hyman You are doing what to which vehicle? Give more information so you can actually get more help. What are you trying to do? What make/model/year is the vehicle?
さんによる
コメントを追加
Have same problem it turned out bleeder screw snaped changed new cylinder and bleed that line was too much air traped there after that. No more spongy brake
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Air trapped in cylinder reppace cylinder then bleed that line
さんによる
コメントを追加
回答を追加する
Vic Hodge さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 123
過去 30 日: 586
今までの合計 76,195
