メインコンテンツにスキップ
The DMC-FZ18 became available in the United States in July 2007. It has a 8.1 megapixel resolution. The DMC-FZ18 is powered by a high capacity Lithium-ion battery and stores images on SD memory cards
2回答 すべてを表示
Dirt in the lens body
I have dirt in between the lens. It looks like a plain piece of glass like a lens filter then the lens behind it. that where the dirt is
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@wakefieldkid this “looks like a plain piece of glass “ does not sound like a dirty lens. Remove the CCD sensor and see if the filter is still in place etc. Use the manual for the disassembly and if you absolutely do think you need to get into the lens. Again, from what you are describing it sounds more like an issue with the CCD.
DMC-FZ18_Disassembly.pdf
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Make sure a clear ultraviolet filter is not screwed on the end of the lens. Often dust will be trapped between the filter and the lens. Look at the side of the filter (if there) and you should see markings indicating size ( example 72mm), brand, and type. These filters can become very tight, but never use any tool to try to remove. Grip with cloth or rubber tipped gloves to remove.
if no filter is screwed on the lens, and you see dust inside, that is a job for a camera repair specialist.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gerold Litschi III さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 201
